Five Lug Question?
Re: Five Lug Question? (BOOSTINSI)
Ok, here is the run down, you are correct in both aspects. To do a 5 lug conversion, you need hub, rotors, calipers, yadda yadda. If you get the 5 lug from a usdm type R it is straight bolt on, bolt off. If you get the JDM conversion, you need to make sure you get the axles with the conversion, then you are set, as long as you have a B series swap, you use the jdm axles along with the usual parts and everything is kosher.
Re: Five Lug Question? (SilverCivic2k)
if you don't have a B series, you can use outer prelude CV joints
jc2801
06-07-2007 10:05 AM
type_racerz
01-05-2003 12:16 AM
