rattle noise
rattle noise
my car started making this really bad rattling noise. it is only under acceration. and if i take the car out of gear the noise will also go away. more noticeable under load. uphill its very loud downhill u can barely hear it.
thanks guys
thanks guys
Re: rattle noise
If it's only making noise when you're in gear then it's probably something with your transmission. Try revving your engine while you're still rolling to make sure.
Re: rattle noise
There is also the bearing between the main shaft and the case. (Other side than the input shaft bearing) That one went bad before the input shaft bearing on my b16 tranny.
