Rad hoses with a b-swap radiator?
Old 04-23-2012, 09:50 AM
Wdpfreak145's Avatar
Default Rad hoses with a b-swap radiator?
So in an emergency I had to purchase a new radiator this weekend. It's a Godspeed half size radiator that was meant for an eg with a b-swap. I had to stretch the upper and lower hoses to fit over the water necks of the radiator. The stock hose clamps wouldn't fit over the necks obviously so used a worm drive clamp. It held up fine last night but I don't want to run any chances. I need to know if b-series radiator hoses will fit on the water necks of the d series block so I can get properly fitting hoses. I don't want to run the risk of blowing off a hose on my way to work.
Old 04-23-2012, 10:54 AM
cvcrcr99's Avatar
Default Re: Rad hoses with a b-swap radiator?
No, they will not.
As long as the clamps on the radiator side are tight, you shouldn't have any problems
dsol
06-27-2017 10:21 AM
chrisfromsrq
06-15-2009 07:24 PM
B18Redline
12-02-2004 09:35 AM
lucasbkellner
10
11-15-2004 04:13 PM
wdskuk
12
01-24-2004 09:38 AM
Quick Reply: Rad hoses with a b-swap radiator?
