Quick Question: Will a 5 speed car starts with Auto ECU?
hi there,
i have a 92 civic si, car wouldn't start so i want to trouble shoot to see if my p28 is bad
will i be able to use p27 nonVtec Auto ecu to start my car with??
thanks guys
thanks guys
Re: Quick Question: Will a 5 speed car starts with Auto ECU?
you have to remove two small resistors...
"Remove rp17 and rp18 below the chip, then replace rp18 with a jumper wire"
once you remove the two resistors and solder a jumper wire on the auto ecu, it totally converts it to a manual ecu. you should have no codes... unless you failed to hook up some kind of sensor...
like running a vtec computer on a non-vtec motor... the computer will be looking for that vtec sensor and thus firing off the code...
like i said this guy will be fine if it clips the correct connections.
thank you for the replies guys
reason why i asked is due to my car wouldn't start and i would like to make sure it's not my stock p28 ecu.
anyways the auto one didn't start my car so problem might be, ignition and main relay..i am gonna look into that now.. thank you
well make sure you have the basics...
spark / fuel / power
check the main relay....
check the dizzy
check the dizzy
by the way, auto ecu won't be a plug and play to a manual car
you will need to bypass 2 or 3 wires in order to get it started
auto computer needs to be converted to manual to work. i never tried just tossing in a auto ecu directly into a 92-95 civic with out the resistor mod.
Fook_me_honda
01-09-2008 11:58 PM
boostin4door
08-24-2004 03:49 PM
