quick question about axles?
Old 11-19-2006, 02:16 PM
NSfit's Avatar
Default quick question about axles?
alright im changing my axles on my eg with a b series. there are 2 axles, one of which is slightly shorter and has a shorter spine on the tranny/ half shaft side. can someone tell me what one is driver side and what one is passenger side?
Old 11-19-2006, 02:19 PM
k20EP3's Avatar
Default Re: quick question about axles? (NScivic)
ummm dont you think that if you try it then maybe you will find out? im guesing that the shorter one goes to the drivers side since the tranny is right there and well the other one would go to the passenger side.
Old 11-19-2006, 02:21 PM
DumpedSi's Avatar
Default Re: quick question about axles? (k20EP3)
it shoudl be obvious which goes to which. The driver side splits into 2 and it cant work any other way
Old 11-19-2006, 02:22 PM
DumpedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20EP3 &raquo;</TD></TR><TR><TD CLASS="quote">ummm dont you think that if you try it then maybe you will find out? im guesing that the shorter one goes to the drivers side since the tranny is right there and well the other one would go to the passenger side.
I'm sure he was trying to figure out before hand to try and save himself some work also, the tranny is on the passenger side not the driver side...
Old 11-19-2006, 02:24 PM
NSfit's Avatar
Default Re: quick question about axles? (Slammed Si)
splits into two what do you mean? they are no different except by like half an inch and one has a shorter spine
Old 11-19-2006, 02:25 PM
NSfit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sure he was trying to figure out before hand to try and save himself some work also, the tranny is on the passenger side not the driver side...</TD></TR></TABLE>
YES THANK YOU SO MUCH!!!!
Old 11-19-2006, 02:28 PM
forcefedferio's Avatar
im guessing you got the car with the motor already in it....in which case the axles should be the same length for the most part but the driver side axle will have a female end that goes onto the intermediate shaft, the passenger side goes straight into the tranny.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si &raquo;</TD></TR><TR><TD CLASS="quote"> the tranny is on the passenger side not the driver side...</TD></TR></TABLE>
not if it's RHD haha j/p
Old 11-19-2006, 02:29 PM
DumpedSi's Avatar
These are what b-series axels should look like the top right and bottom peice are go together and make the driver side axel, the top left is the passenger
Old 11-19-2006, 02:31 PM
NSfit's Avatar
no its a cable tranny all the axles have male ends and the half shaft has a female end. sorry for not saying that
Old 11-19-2006, 02:34 PM
k20EP3's Avatar
Oh yeah my bad im thinking of my car...sorrrryyyyy
Old 11-19-2006, 02:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic &raquo;</TD></TR><TR><TD CLASS="quote">no its a cable tranny all the axles have male ends and the half shaft has a female end. sorry for not saying that</TD></TR></TABLE>
being that it's a cable tranny and they all have male ends then you have a 90-93 integra axle setup in which case i believe the shorter splined end will go into the intermediate shaft....i gave away my 90-93 integra axles cuz i don't have a 4th gen and didnt need them or else i'd go look and make sure for ya...good luck though
Old 11-20-2006, 11:20 AM
efjon1225's Avatar
Default Re: quick question about axles? (1jdmferio)
St Jimmy
05-22-2007 01:47 AM
nicehatchy
08-08-2005 04:25 AM
hellogoodbye
04-05-2004 04:11 PM
JDMBB2
02-20-2004 07:31 AM
kshymkiw
11-28-2002 05:54 PM
Quick Reply: quick question about axles?
