Coling Fan Problem
Old Jan 21, 2002 | 08:08 AM
SiViK-R's Avatar
Default Coling Fan Problem
Sup techs...im starting to think i have the worst of luck...i fix one thing then something else goes wrong...anyways...i my cooling fan isnt turning on whenever it suppose to...i tested all wires all the way to the relay switch...i even took apart the relay switch and tested by tapping the metal together and the fan works...whats wrong?...is something wired wrong becuase i did an engine swap, but i dont think it would affect how the cooling fan works...it like the cooling fan doesnt know when to turn on...help please
Old Jan 21, 2002 | 10:09 AM
SiViK-R's Avatar
Default Re: Coling Fan Problem (SiViKbOi)
anyone?????
Old Jan 21, 2002 | 10:55 AM
89crxPOS's Avatar
check your fan motor by taking the connector off of the temp sending unit and using a jumper on the connector to make a compete circuit
Old Jan 21, 2002 | 02:13 PM
bob01721's Avatar
There's usually a thermo-sensor that tells the fan when to turn on. That sensor usually controls the fan relay.
It sounds like that sensor isn't working or isn't connected.
Old Jan 21, 2002 | 04:27 PM
iceburgslim's Avatar
Default Re: Coling Fan Problem (bob01721)
I don't think the thermo-sensor is connected........
Old Jan 21, 2002 | 06:49 PM
HaUTSaauce's Avatar
New User
check the sensor like he said above me
Old Jan 21, 2002 | 08:41 PM
SiViK-R's Avatar
Default Re: Coling Fan Problem (HaUTSaauce)
does anyone have a picture of what it looks like or can someone explain to me where its located...
Old Jan 22, 2002 | 04:53 PM
SiViK-R's Avatar
Old Jan 22, 2002 | 05:07 PM
rainforest's Avatar
You can fix it and have a mod by getting a adjustable fan swich. You can get one from autozone, you adjust it to the temputure you want your fan to turn on at.
Old Jan 22, 2002 | 08:09 PM
Luv2roost's Avatar
Default Re: Coling Fan Problem (rainforest)
I did the fan switch thing and it was way easier than trying to figure out the relay mess after motor swap.
Old Jan 23, 2002 | 01:22 PM
OneSunkCivic's Avatar
yeah it's right on the side og the block and be careful because radiator fluid will come out when you take it out I would just let the engine warm up and check for a positive from the wire that plugs into it if it doesn't send a positive then the sensor is bad.
Old Jan 24, 2002 | 02:02 PM
SiViK-R's Avatar
Default Re: Coling Fan Problem (OneSunkCivic)
okay thanks for the info!
zx92027xz
17
Sep 29, 2024 09:55 AM
acg21
Honda Civic (2006 - 2015)
Jul 2, 2016 08:11 AM
peteyparado
May 12, 2013 08:43 AM
tunerEF9
Apr 30, 2010 11:12 AM
FONK
Jan 12, 2006 03:03 PM
