Questions on Replacing cable YS1 gsr trans with a hydraulic b16...
i had a gsr swap out of a 92 gsr that i put in my eg. The motor blew but i kept the trans and swapped in a ls motor. The gsr trans is at the end of its life and i want to put in a hydraulic trans.
Am i going to have to replace the shift linkage?
I should be good with the clutch? its a stage 2 clutchmaster
thanks
thanks
Seagull Management
Re: Questions on Replacing cable YS1 gsr trans with a hydraulic b16...
As long as you used a '94 - '01 Integra linkage then you'll be ok. Clutch will work fine, but you'll need a hydro release/throwout bearing.
not sure about the linkage, any way to tell?
well if im using a trans from a 93 gsr, wouldnt i have to use that linkage versus a 94 and up?
nicknack25
08-11-2017 08:51 PM
Ostrich2.0
04-05-2011 05:52 AM
