questions regarding b20vtec
Old 09-19-2006, 11:23 AM
spankurbooty's Avatar
Default questions regarding b20vtec
Well I have some questions.. I currently have a b16a and I just picked up my b20... I have plans to go b20vtec. For now I'm gonna drop the b20 in my hatch. But will it run good with my b16 tranny? What tranny would work good for my setup? Also same question for an ecu.. Thanks
Old 09-19-2006, 11:44 AM
2wheelhunter's Avatar
Default Re: questions regarding b20vtec (spankurbooty)
tranny you'll be fine, the b16 has really short gears, which is good as long as your staying all-motor, if u want to go boost then look into the LS trannys, i beleive there is a kit to put the vtec head onto the b20 block, it comes with dowlings and headgasket and i beleive an oil line, the ecu you may have some slight problems running a lil lean, try a fuel pressure regulator and a VAFC to rich and lean it out, if properly done those b20vtecs are fun as expletive, o yeah have fun snapping axles lol
Old 09-19-2006, 11:48 AM
Default Re: questions regarding b20vtec (2wheelhunter)
No I'm not looking into boosting it... I have an ecu that has a slot so it can hook up to a comp and be tuned... can I just do that? Go and get it re tuned? Also would b16 headers fit the b20? Snapping axles? That's no fun
Old 09-19-2006, 11:50 AM
ziich2's Avatar
http://www.B20vtec.com
Old 09-19-2006, 11:52 AM
turbociviccoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankurbooty &raquo;</TD></TR><TR><TD CLASS="quote">No I'm not looking into boosting it... I have an ecu that has a slot so it can hook up to a comp and be tuned... can I just do that? Go and get it re tuned? Also would b16 headers fit the b20? Snapping axles? That's no fun </TD></TR></TABLE>
yes the header will fit
Old 09-19-2006, 12:05 PM
Default Re: questions regarding b20vtec (ziich2)
Thaks for the link.... obvious name lol
Old 09-19-2006, 09:12 PM
any more suggestions for an ecu?
Old 09-20-2006, 06:41 PM
so i guess i have to swap out my intake manifold from my b20 because its too high... im gonna put my b16 manifold... which injectors should i use?
Old 09-20-2006, 07:14 PM
knockout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankurbooty &raquo;</TD></TR><TR><TD CLASS="quote">so i guess i have to swap out my intake manifold from my b20 because its too high... im gonna put my b16 manifold... which injectors should i use?</TD></TR></TABLE>
i believe you have to use the b20's.
Old 09-20-2006, 07:32 PM
Default Re: questions regarding b20vtec (knockout)
what about ecu? i have a pr4 and my b16 ecu
pinoy2o9
06-19-2008 12:03 AM
crxpwr1
10
04-13-2007 07:55 AM
CRX_GUY_123
02-29-2004 07:47 PM
jDMJeRk
12-27-2003 08:40 AM
eeekthehatch
12-04-2002 07:32 AM
Quick Reply: questions regarding b20vtec
