Question about removing door panel
Old 04-24-2004, 09:17 AM
TarheelFan's Avatar
Default Question about removing door panel
I feel really lame asking this, but I'm taking the door panels off my '93 hatch. It has manual windows -- how do the window cranks come off??
Old 04-24-2004, 09:22 AM
xturbovtecx's Avatar
Default Re: Question about removing door panel (TarheelFan)
There should be a "C" shaped clip holding it on. I use a rag to pull it out. I push panel in and see which way its siting. Grab a rag on conners pulling it tight in the center. Then on the open end of clip, I slide the rag up. it should pop out. It sometimes takes a few trys. Hope this helps.
Old 04-24-2004, 11:21 AM
EL SARGENTE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xturbovtecx &raquo;</TD></TR><TR><TD CLASS="quote">There should be a "C" shaped clip holding it on. I use a rag to pull it out. I push panel in and see which way its siting. Grab a rag on conners pulling it tight in the center. Then on the open end of clip, I slide the rag up. it should pop out. It sometimes takes a few trys. Hope this helps.</TD></TR></TABLE>
yea it's a c clip, it can be kinda difficult to get the bastard off at first....then once you get used to it you'll be able to take it off like nothing
Old 04-24-2004, 12:34 PM
TarheelFan's Avatar
Default Re: Question about removing door panel (Superhonda8301)
Once I knew what I was looking for, I was able to get a small screwdriver on it. Popped it right off ... about 10 feet out into the grass. lol. The second one I shielded with my hand. Putting them back on was a poser until i figured out that you put the clips on then cranks first, then they snap on. Thanks for the help!
X93siX
01-30-2010 05:34 PM
DOHC_C-REX
10-02-2005 10:28 AM
Moonbus
01-03-2004 08:41 PM
DRAG1320ciVHBKsi
11-29-2002 09:50 AM
Zulu888
08-29-2001 07:18 PM
Quick Reply: Question about removing door panel
