Question about corner light
I have this problem where the driver side corner doesnt stay lit when the headlights are turned on but when I use the left turn signal it blinks, I assume it is a fuse problem but I can't find the fuse for it. If its the fuse problem where may I find the fuse for it or what else can it be ?
Darth ModerVader
Re: Question about corner light (simplypinoyy)
Actually, it sounds as if the low-wattage filament of the bulb has burned out. Have you tried replacing the bulb?
Re: Question about corner light (Padawan)
the bulbs are brand new, I figured it was a fuse though for that specific reason. Any other suggestions ?
where is the fuse for the parking lights ? (the corners being lit; i dont know what the correct term for them)
Re: Question about corner light (Outrun)
i'll do that and also i'll try to see if i can replace the wiring for that corner from another hatchback
