Quaife LSD problem with axle on passenger side
Old Jul 31, 2007 | 12:33 AM
92jdmhatch's Avatar
Default Quaife LSD problem with axle on passenger side
Okay so here is the problem.... to begin with i have an S80 GSR tranny...
I had the OBX L.S.D in the car and i would constantly spit axles out and they wouldnt want to go back in....so i did some measuring and etc....came to conclusion that the grooves for the snap ring to snap into place were so far in that the axle would sit flush in but the snap ring on the axle would never reach the grooves.....
I went ahead and meausred the distance on the grooves in the quaife and found out that it is correct.....i purchased the quaife since it was the way to go.....the problem i am having now is that the lip on the housing of the L.S.D is about 1/8 of an inch longer and the axle is bottoming out where the axles stop point is on the lip and the lip on the outer part of the diff...
couple things i tried
putting the axle in the ORIGINAL diff and the axle locks into place
i tried couple different axles...GSR SI etc..
anyone have any ideas as to why i am having this problem?
Old Jul 31, 2007 | 01:30 AM
eg-owns you's Avatar
Default Re: Quaife LSD problem with axle on passenger side (92jdmhatch)
I have Quaife LSD 4.9 final dirve in my B20 Vtec i love it do death i have never had a problem with quaife at all a nice clean install of it and that axles obx i allway's have hurd nasty things about it. you sure you have the correct axles cuz i was runing Gator 2's on my broke one of them and put a stock axle in from auto zone had no problems
Old Aug 17, 2007 | 05:55 PM
racin_jayson's Avatar
bump because I am having the same problem, any solution yet??
92jdmhatch
Feb 6, 2008 03:20 PM
92jdmhatch
Jul 31, 2007 08:40 AM
ilikehonda
Jan 20, 2007 07:56 PM
longuyen88
Jun 16, 2006 09:41 PM
