Quaife / OBX Lsr problem with gsr tranny passenger side axle
Old Jul 31, 2007 | 12:36 AM
92jdmhatch's Avatar
Default Quaife / OBX Lsd problem with gsr tranny passenger side axle
Okay so here is the problem.... to begin with i have an S80 GSR tranny...
I had the OBX L.S.D in the car and i would constantly spit axles out and they wouldnt want to go back in....so i did some measuring and etc....came to conclusion that the grooves for the snap ring to snap into place were so far in that the axle would sit flush in but the snap ring on the axle would never reach the grooves.....
I went ahead and meausred the distance on the grooves in the quaife and found out that it is correct.....i purchased the quaife since it was the way to go.....the problem i am having now is that the lip on the housing of the L.S.D is about 1/8 of an inch longer and the axle is bottoming out where the axles stop point is on the lip and the lip on the outer part of the diff...
couple things i tried
putting the axle in the ORIGINAL diff and the axle locks into place
i tried couple different axles...GSR SI etc..
anyone have any ideas as to why i am having this problem?
Modified by 92jdmhatch at 10:20 PM 8/2/2007
Old Jul 31, 2007 | 02:37 AM
DaveF's Avatar
Default Re: Quaife / OBX Lsr problem with gsr tranny passenger side axle (92jdmhatch)
you put the left axle on the right side ?
Old Jul 31, 2007 | 02:40 AM
1992Si's Avatar
You'll want to contact "transzex" on http://www.tubobd16.com or on Dseries.org.
He also goes by Masta Bone (sp)
Old Jul 31, 2007 | 02:50 AM
DaveF's Avatar
Default Re: (1992Si)
come on grand pa, he also posts on this forum.
Old Jul 31, 2007 | 07:33 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (dturbocivic)
mista bone not masta bone..lol
Old Jul 31, 2007 | 08:43 AM
92jdmhatch's Avatar
Default Re: Quaife / OBX Lsr problem with gsr tranny passenger side axle (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you put the left axle on the right side ? </TD></TR></TABLE>
no that cant be...because i tried taking my friends axle off his 99 si and tried it....same ****
Old Jul 31, 2007 | 12:09 PM
Camp1320motorsports's Avatar
nice photo shop..
alex it seems to me that the pic you drew for the axle looks like a 90-93 axle.
the 90-93 DA axles are long splines. the correct axle you need for the passanger side is half splines and half shaft. the spline are not suppose to go all the way down. bring us the axles and let us take a look at it... thats very fishy
Old Jul 31, 2007 | 04:56 PM
champLSinteg's Avatar
Default Re: Quaife / OBX Lsr problem with gsr tranny passenger side axle (Camp1320motorsports)
The same thing happened to me with my OBX. I posted here and I was told to just pound it in becuase the clip sometimes has trouble compressing and getting in there. After pounding and puting it back together numerous times I decided something was wrong with the diff. I was so pissed that i started grinding down the axle where it sits on the diff to see if it could go in deeper. It didnt work. I finally contacted the guy I purchased it from and he gave me a new one. No problems at all with this one. I tested it before I installed it and the axle locked. I could pull the axle out easily with my hand on the bad diff. what i am saying is you probably need a new one.
Old Jul 31, 2007 | 06:43 PM
DRIVENRacing's Avatar
i ran an obx v2 on one of my race cars and it worked AWESOME...
Old Jul 31, 2007 | 08:38 PM
da_dude's Avatar
I had a problem with my obx lsd on my d16 tranny. Passenger side will go in but have alot of play and leaks alot of tranny fluid. I took it out so many times and try reinstalling it over and over again. Even try it with my stock tranny I took out. At the end it turns out that the axle oil seal was bad. I'm not sure if this will help but I just thought I share it. No more play and leak.
Old Jul 31, 2007 | 10:27 PM
92jdmhatch's Avatar
Default Re: (turb20_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Camp1320motorsports &raquo;</TD></TR><TR><TD CLASS="quote">nice photo shop..
the 90-93 DA axles are long splines. the correct axle you need for the passanger side is half splines and half shaft. the spline are not suppose to go all the way down. bring us the axles and let us take a look at it... thats very fishy</TD></TR></TABLE>
no i for sure have 95 acura integra passenger side axle....no doubt about that...because i even tried my buddies passenger side axle from his 99 si....i will take the tranny apart and bring it in.....maybe theres something i am not seeing that you can help me out with.....soon to visit the shop....
^^^^ thats what i call good customer service...thanks Camp1320
Old Aug 1, 2007 | 12:24 AM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">You'll want to contact "transzex" on http://www.tubobd16.com or on Dseries.org.
He also goes by Masta Bone (sp)</TD></TR></TABLE>
it's Mista Bone
Who installed the OBX, what bearings were used, how was it shimmed?
Possible they installed a the GSR LSD with LS bearings and shifted it 3mm towards the driverside......pics help greatly.
Old Aug 1, 2007 | 07:51 AM
1992Si's Avatar
Default Re: (Arturbo)
Well, I see you all know who I was talking about,
Mista Bone is the man...
Old Aug 1, 2007 | 08:57 AM
92jdmhatch's Avatar
Default Re: (Mista Bone)
welllthe obx is long gone....i installed both of them...with the quaife...it wouldnt make a difference where the LSD is sitting..because the axle is not bottoming out on the tranny...its bottoming out on the diff itself....so even if u pulled it out...and try to shove an axle in there from outside it would do the same...
2 different problems with 2 different diffs. same side axle.......anyone got somethin to blow up this car?
Old Aug 1, 2007 | 09:38 AM
AutotechRD's Avatar
Default Re: (92jdmhatch)
What's the measurement from the shoulder to the clip groove? I'll compare that to a the drawing of what the diff is supposed to be (Quaife). Also, take a look into the axle bore of the diff., and see if there is a chamfer at the start of the splines inside the side gear. The Chamfer should have a larger O.D. than the spline to help collapse the snap ring. It is possible that the gear was installed backwards.
Old Aug 2, 2007 | 09:15 PM
92jdmhatch's Avatar
Default Re: (AutotechRD)
WELL....i ended up doin something i really didnt want to do....take the tranny apart and pull the diff out...which i did......turns out...there had been a misunderstanding and i had the wrong part....got the new one.....checked the measurements and everything was fine.....thanks to Tom at Camp1320 for pullin through over night like he promised he would.
Old Feb 6, 2008 | 03:20 PM
tightDA8's Avatar
thread resurection:
i am having the same exact problem with my DA. It has a YS1 with an OEM ITR diff...Passenger side axle goes in all the way but c clip will not lock in the grove...if anyone has any new pieces of advice, please share.
92jdmhatch
Aug 17, 2007 05:55 PM
92jdmhatch
Jul 31, 2007 08:40 AM
ilikehonda
Jan 20, 2007 07:56 PM
redstorm82
Dec 18, 2001 07:33 AM
