Putting a Shift Boot on Auto EJ
Re: Putting a Shift Boot on Auto EJ
Well your gonna need
1.screwdriver
2.shift boot
3.6pack of beer any kind is good
1.ok you gonna take the to screws from the manual stick there located by the top on each sides one you have that off it should come off easy.
2. You gonna start taking out the bolt from the center council oneces you took that off there should be like four more bolts on the bottom of the center council take those off an just put the shifter boot on there an put it back same way you took it off an you should bee good to go an it will look almsot like a manual car........
I suggest you do an auto to manual swap in the future.. But good luck if you run into any trouble just let me know
1.screwdriver
2.shift boot
Well i think one of my guy went to autozone an just bought a different shift **** for it an it ended up fitting but your gonna have to play with it for a while
1. remove auto shifter handle/****
2. remove center console
3. slip the boot on over the automatic plastic bezel
4. put center console on so that the edges of the boot are hanging down around the automatic shifter bezel and the console pushes down the boot to make it look like it was meant to be
5. put the auto **** back on
be sure to give the top of the boot enough slack so the shifter can move all the back forward and backward.
and you can't put a manual shift **** on it, the auto shifter has no threads and needs to be pushed down anyway to move the shifter. it's stupid/rice to do that anyway.
susboy102
07-16-2014 08:31 AM
Smith Wise
06-26-2003 06:01 AM
