purge control solenoid?
ok i just got a skunk2 manifold and i was putting it on today and it dosent have the little place in the corner to mount it and i know jdm engines dont have it. I was just wondering if I could disconnect it and not run it? Would that hurt performance or cause a cel just wondering thanks
i would just buy a longer length of vaccum hose and zip the the solenoid to the brake booster vaccum line or something. you could run w/o the entire charcoal canister setup by just simply capping off the connections on the tb and i/m
Re: purge control solenoid? (NAPIER)
ok guys bear with me im new at this, But i have a 95 civic 1.6L sohc vtec according to the Hayes manual what they called the purge control solenoid was located by the rear part of the throttle body which is also got a purge control solenoid sensor ??? Honda wants 130-150 dollars for a little sensor held in by a single phillips screw and is the size of a quarter. Anyone know where i can get that sensor for cheaper than that ??
Thanx
Newbie
Thanx
Newbie
