programming keyless entry?
Old Mar 3, 2008 | 12:01 PM
Lordofdark176's Avatar
Default programming keyless entry?
alright so i have a 2000 honda civic ex 2 door. when i bought it from a dealership (used) whoever had the car before had an aftermarket headunit in it. my dad had the dealership install a stock headunit because the other one was garbage. I am almost positive its an Si one, which would mean it has the keyless entry module in it (its amber backlit), so i found out i can program a keyless entry remote to my car myself. i bought one off of ebay and just tried to program it, i cant get it into the programming mode, i've seen multiple differnet ways of doing it and even the one in the 2200 page pdf of a honda service manual didnt work. My friend told me i have to take it to a dealersihp but i dont want to pay $80 [freak]in dollars for it. is that my only option? help please.
Old Mar 3, 2008 | 12:21 PM
Eran's Avatar
HT White Ops
Only the 96-98 EX/LX/HX radio had the keyless entry module in it.
On all 99-00 Civics, the module is in the driver's door. Being that you have an EX, you do have a door module, and you just need to get a key fob and program it according do your owner's manual.
Old Mar 3, 2008 | 12:23 PM
NOFX's Avatar
H-T White Ops
EXes came standard with keyless entry. The Si radio has nothing to do with it. The keyless entry is tied to the radio on '96-'98s, but is separate on '99-'00s.
IIRC, there were optional amber lit radios for other trims, not just the Si trim. I know there were for '96-'98s, but I'd have to check for '99-'00 again.
Are you sure your remote matches to the stock keyless receiver for your car.
Old Mar 3, 2008 | 01:06 PM
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">EXes came standard with keyless entry. The Si radio has nothing to do with it. The keyless entry is tied to the radio on '96-'98s, but is separate on '99-'00s.
Are you sure your remote matches to the stock keyless receiver for your car.</TD></TR></TABLE>
it isnt the same remote, i bought it off ebay for $15.
I just went to the honda dealership and they tried 2 other remotes they had there with no success, the guy said i need an EX radio and it will work. so is there anything i can do about this to make it work?
Old Mar 3, 2008 | 01:55 PM
Taimaishui14's Avatar
Default Re: (Lordofdark176)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Only the 96-98 EX/LX/HX radio had the keyless entry module in it.
On all 99-00 Civics, the module is in the driver's door. Being that you have an EX, you do have a door module, and you just need to get a key fob and program it according do your owner's manual.</TD></TR></TABLE>
Read above. It has nothing to do with the radio, as you have a 00 Ex. Its in the door, as they said.
Old Mar 3, 2008 | 04:49 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 &raquo;</TD></TR><TR><TD CLASS="quote">
I just went to the honda dealership and they tried 2 other remotes they had there with no success, the guy said i need an EX radio and it will work. so is there anything i can do about this to make it work?</TD></TR></TABLE>
Whoever you talked to is confused.
99-00 EX coupes, 99-00 Si coupes and 99-00 EX sedans all use the same keyless remotes and control units (in the car). Even if you had no radio at all, your keyless should work fine.
Old Mar 3, 2008 | 06:15 PM
so why couldnt i or they get it into programming mode? they even tried 2 other remotes they had there. it should have the keyless thing from the factory so thats why im confused.
Old Mar 3, 2008 | 06:25 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 &raquo;</TD></TR><TR><TD CLASS="quote">so why couldnt i or they get it into programming mode? they even tried 2 other remotes they had there. it should have the keyless thing from the factory so thats why im confused.</TD></TR></TABLE>
Open the door up and see if the control unit's there. It could have been removed or it might have malfunctioned. You might need a new one.
Old May 25, 2008 | 07:16 PM
acake em1's Avatar
Colonel Cake Mix
Default Re: (NOFX)
For anyone with a 99-00 civic... I just got a fob from a friend and programmed it using the instructions from above and it worked perfectly. Thanks to the user who posted that, and to anyone trying to do it, its very easy.
Thanks again
Old May 26, 2008 | 04:41 AM
RyanA's Avatar
Default Re: (acake em1)
The door lock control module is in the door. The actual keyless entry receiver is in the driver side kick panel area.
Old Jul 24, 2008 | 04:58 AM
tyler302's Avatar
Does my 99 si come standard with a keyless module? Or only the EX models?
heatjust
Apr 19, 2014 02:52 PM
goodluckboyz
Jul 20, 2009 11:32 PM
seanyboy
Mar 16, 2008 11:51 PM
d2privat11
Nov 11, 2005 10:51 PM
