Problems after swap. Please Help...
This is also posted in the "hybrid"section. any help is appreciated...
Originally i was going to do my motor swap myself but due to work related commitments i decided to bring it to a local performance shop. I have a 97 civic ex 5spd, and i had a B18c GSR motor installed. the person i bought it from told me it was an OBD2 but it turned out to be a OBD1. The shop sold me the OBD1 to OBD2 cable and installed everything for me. i also had new headers, intake, and catback system installed, along with new spark plugs, wires, and a new cap and rotor.
I finally picked the car up today (shop had it about a week) and drove it home. The shop is about 25 miles from my house. My car didnt feel like it had the power i thought it would, but figured i just had higher expectations. When i pulled in my driveway the check engine light came on. i turned the car off then on again and the light went away.
2 hours later i went out to run to the store. car started great, but as i drove down the road the check engine light came on again and within seconds my speedometer and odometer shut off (tach/gas/temp still worked). i drove back home and checked the wire harness that plugs into the tranny and it was still plugged in. when i restarted my car the check engine light was off.
as i drove down the block again the light came back on and the speedo shut off but i kept driving. as i entered a main road my car bogged down for a second then was fine. i returned home and stalled in my driveway. my car turned back on again and check engine light went off.
the shop opens again on monday so i plan to have my car towed back there. before i go through all of this trouble, does anyone have any suggestions they could give as to why i am having these problems?
i've never delt with an obd2-1 harness, but i'm sure there's move involved then just slapping on the harness.
did you bother to check the codes it's throwing? turning it off and on doesn't clear the codes.
is this a reputable shop you went to?
Re: (skUnK2jdm)
i have a OBD1 p72 ecu. im throwing a 17 code (VSS) i checked the connecter on my tranny and its plugged in all the way. could a bad VSS cause my car to stall?
**Update. i just rechecked and i am also throwing a code 22 (VTEC pressure valve).
Modified by erich73 at 2:17 PM 4/15/2007
Re: (erich73)
i found a green/yellow wire that had been stripped back and left exposed in a green plug by my ECU. i checked my helms manual and found this wire to be my VTEC solenoid wire. it must have grounded out against my ECU or chasis. i took the car for a test drive after resetting everything and im still have accelerating issues where the car sputters and feels like its going to stall.
my check engine light came back on so i checked for codes again. #8 came up (top dead center sensor).
i checked all of the plugs on my distributer and they were all plugged in. could my dist. be bad?
