Problem Electrical System
Old May 10, 2006 | 09:00 AM
ScottC's Avatar
Default Problem Electrical System
I have a 98 Civic DX Hatchback with 138,000 miles. The battery seemed to be losing power so first thing I figured was testing the battery, it is fine it's only a year old. Next I figured replacing the alternator. Had it tested it wasn't charging the battery any longer. Replaced the alternator. Problem is still here. When I drive the car it uses battery power and alternator doesn't recharge it. The electrical system seems to fluctuate up and down continously because the headlights go dim and bright over and over the whole time the car is running and as the battery loses charge it gets worse until it will eventually drain the battery totally. Any ideas? The computer unit? I have no idea.
Scott
Old May 10, 2006 | 10:22 AM
fmrprojects's Avatar
Default Re: Problem Electrical System (ScottC)
check your battery terminals and see if they are corroded, that would cause it to be weak. and then check the tension on the alternator belt, too loose will not produce the maximum amps
Old May 10, 2006 | 11:31 AM
ScottC's Avatar
Default Re: Problem Electrical System (fmrprojects)
battery terminals are clean and tight and tension on belt is tight...I'm at a loss on this one.
ALLDAY-24
18
May 3, 2011 08:25 AM
9sludei0
Aug 29, 2010 12:22 PM
97_hatch
May 20, 2008 03:26 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
Syndacate
Aug 14, 2007 05:10 PM
