problem with ecu tried checking code...
Old Oct 5, 2004 | 08:15 AM
dropd4door's Avatar
Default problem with ecu tried checking code...
i have a 92 dx with a newer ls engine... i have a chiipped out ecu and it runs no cel but when i put a stock PR4 ecu outta a 93 ls integra ecu. i run a cel after about 5 minutes of letting it sit and on my air fuel gauge it goes to run and disappears i looked for the service connect with "One wire is black with a white stripe and the other is a red with a black strip.. " but cant find it i found two other plugs one has a green with a white stripe, and a light blue wire... and the other plug has a red solid and green with a white stripe. and they were in this little rubber green thing,,, anyone have any idea whats going on??? ive checked codes on ef's before connected the serivce wires and watch the ecu seemed easier lol... any thanks guys
Old Oct 5, 2004 | 10:02 AM
snatch's Avatar
Default Re: problem with ecu tried checking code... (dropd4door)
try jumping the plug that was in the green rubber thingy...
Old Oct 5, 2004 | 10:23 AM
dropd4door's Avatar
Default Re: problem with ecu tried checking code... (******)
there are two plugs each with 2 wires
Old Oct 5, 2004 | 12:07 PM
snatch's Avatar
I'm not sure which colors to use for the teg ECU. Have you tried both of them?
Old Oct 5, 2004 | 12:38 PM
Grimm's Avatar
is it an obdi engine? your running an obdi ecu? other than that... sorry...
Old Oct 5, 2004 | 04:14 PM
dropd4door's Avatar
the ecu has nothing to do with the wires that should be coming outta the service connector their implanted in the car.... yeah the ecu is obd1 and the wirin is also
Old Oct 5, 2004 | 06:20 PM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropd4door &raquo;</TD></TR><TR><TD CLASS="quote">the ecu has nothing to do with the wires that should be coming outta the service connector their implanted in the car.... yeah the ecu is obd1 and the wirin is also</TD></TR></TABLE>
true...I don't know what to tell you.
xander1100
Engine Management and Tuning
Jul 15, 2009 08:16 PM
O RLY
10
Jul 2, 2007 07:28 AM
integ69
Mar 14, 2006 09:31 AM
ludatic
Nov 2, 2003 10:46 PM
