Problem with the driver side headlight
Old May 13, 2007 | 06:31 PM
blk2mid2sol's Avatar
Default Problem with the driver side headlight
i have a 94 honda del sol
my driver side headlight is not working and is currently being tapped into my passenger side to get power
the bulbs were replaced and the wiring harness was also replaced. checked all fuses and still dont know what is going on...
any suggestions, ideas?
Old May 13, 2007 | 08:27 PM
Default Re: Problem with the driver side headlight (blk2mid2sol)
Old May 15, 2007 | 02:53 AM
Old May 15, 2007 | 04:25 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Could of been that the wire was overloaded and burnt somewere in the harness. I repair this all the time when people hook up cheap bulbs from the swapmeets and try to modd there lighting system. I would not run the driver side off the passanger side unless you want to do the same damage to it. Either fix the problem or use the passanger side to trigger a relay to turn both on.
Old May 15, 2007 | 05:12 AM
Default Re: Problem with the driver side headlight (wrx-killer-Sti eater)
so... i am probably going to have to trace the wire?
Old May 15, 2007 | 06:22 AM
If not do what I mention above. It will not hurt anthing and will make the lights brighter.
Old May 15, 2007 | 06:25 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">use the passanger side to trigger a relay to turn both on. </TD></TR></TABLE>
This is what I'd suggest doing. It's easier than trying to trace the problem, and the results will be better.
Old May 16, 2007 | 07:33 AM
... inexperienced with this... how would i go about doing it?
Old May 16, 2007 | 08:42 AM
Padawan's Avatar
Darth ModerVader
http://users.mrbean.net.au/~rover/headlamps.htm
Old May 16, 2007 | 02:37 PM
Default Re: Problem with the driver side headlight (Padawan)
thanks!! i should be able to figure it out.
Old Jul 12, 2007 | 03:35 PM
got the relays in, lights are a lot better now thanks!!!
tupakiz
Nov 18, 2010 04:22 PM
jromulo
Audio / Security / Video
Jun 24, 2008 04:43 AM
ek7shane
May 18, 2008 10:51 PM
Senbonzakura
Jan 4, 2005 07:48 PM
