Problem #2
Problem #2
Well I replaced the saprk plug tube gaskets, the valve cover gasket, (refer to Leaky Valve Cover) and all that went smoothly. But after I got everything put back together, and took it out for a drive, and after about 10miles or so, it started shaking, and vibrating below 2000 rpm, in any gear. A friend told me its the struts, and that his 240sx, and RX7 do the same.....so help me out again. Thanks
Re: Problem #2 (Honda4CX-R)
sounds to me like it's running on 3 cylinders. Check to make sure one of your spark plug boots didn't pop off.
Blown shocks will not cause the car to vibrate or shake.
Re: Problem #2 (94CivicSi)
i have had that problem too, take all the spark plug wires off and press them down again as hard as you can...
are you getting a check engine light??
thanks,
mike
thanks,
mike
Re: Problem #2 (1 Evil Civic)
Well, I know everyone has done this before so check it out...
Make sure that each wire is connected to the proper spark plug to its correspondent cylinder.
