pressure plate problem
I ordered a new clutch and pressure plate from hondaautomotiveparts.com and when I went to install my pressure plate I ran into a problem. As you can see from the picture the dowel pin hole and bolt hole are opposite from the flywheel.
My only guess is that I don't have the right pressure plate. I ordered it for a del sol VTEC b/c that is where my engine came from. Right now, I'm trying to figure out what is going on. Did I get the wrong pressure plate? I don't want to order another one and get the same thing.
Modified by Ej6B20 at 1:20 AM 7/16/2004
Re: (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">did you try rotating it??</TD></TR></TABLE>
haha yup common problem
Re: (2.0L EK)
yeah try rotating it, but it have to align with the flywheel correctly with the mark or white mark. other than that, they might have giving u the si sohc vtec one instead of the dohc vtec
Re: (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">yeah try rotating it, but it have to align with the flywheel correctly with the mark or white mark. other than that, they might have giving u the si sohc vtec one instead of the dohc vtec</TD></TR></TABLE>
I rotated it several times and then a couple more times. I'm stumped
Re: (Ej6B20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6B20 »</TD></TR><TR><TD CLASS="quote">I rotated it several times and then a couple more times. I'm stumped</TD></TR></TABLE>
keep trying lol, it would help if you compare it with the stock PP.
Re: (99FBPSi)
I tossed that one in the trash two months ago. I'm trying to get my swap together. I guess I will go to autozone tomorrow and compare plates.
Re: (humbleHX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by humbleHX »</TD></TR><TR><TD CLASS="quote">looks like you got a sohc PP.</TD></TR></TABLE>
then i probably got a sohc clutch too
Re: (Ej6B20)
Just by looking at the pic, I can tell you that its not rotated in the correct postion. A PP will only fit one way on a flywheel, and it looks like it is in the wrong position. Like everyone said, try rotating til all the bolt holes are aligned, and if its still wrong, its probably teh wrong PP. Look at the part numbers.
Re: (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">Just by looking at the pic, I can tell you that its not rotated in the correct postion. A PP will only fit one way on a flywheel, and it looks like it is in the wrong position. Like everyone said, try rotating til all the bolt holes are aligned, and if its still wrong, its probably teh wrong PP. Look at the part numbers.</TD></TR></TABLE>
yeah there is only one way the pp can go into the flywheel.
check the part number on the bag that came with the pressure plate and call honda to make sure you have the right one ....
edit: if its not the right part number call hondaautomotiveparts to see if they will give you a new one...
Johnmadsen
02-11-2019 07:19 AM
Just Checking In
03-27-2003 09:41 PM
