Practical Fun: 1998 Civic Sedan GS-R
I've been a fan of Honda since my first car - a 1991 Tahitian Green Pearl Civic Si - which stayed with me for almost 8 years.
It was Honda's practical, yet still invigorating approach to design that made me a fan. My family has owned many Honda vehicles since, but I want to recapture the essence of what Honda achieved with the Si - in my current car.
I have a 1998 Civic Sedan DX 5 speed with a B18C. Here is a run-down of what is done to the car (with some noted changes below):
I've changed a few things:
- AEM short ram intake (the old one was ugly and didn't fit very well)
- Eibach Prokit springs with spacer Koni strut spacer rings (gave a closer to stock appearance, while maintaining a mild spring rate increase)
- Tons of maintenance (replacing bushings, gaskets, new shift forks, DSS (level 0) axles, etc.)
The car is in very good condition, but still needs minor tweaks.
I am not trying to create a drag monster or even 200 whp car; what I'm trying to do is make a car that looks and feels like something that could comfortably take a seat in Honda's performance line-up. Also, right now I net 34-36 mpg during mixed driving and I really don't want to let that slide too much. I need help achieving my goal, because I'm not as savvy as most in the H-T community.
Here are the things I want to address right now:
- The exhaust looks stock (which is nice), but it is too loud (not so nice). I'm looking into a black Yonaka 2.5" cat-back system. I've seen a lot of good reviews and I like the way it looks and sounds - the price doesn't hurt either.
- The DC Sports header has got to go. The ground clearance isn't the best and, when the car was lower, it got beat up pretty good on the underside. I'm kind of leaning toward a stock GS-R manifold.
I'm not interested in shifting the power curve to the right; but an increase in power, without sacrificing drive-ability, wouldn't be bad. I'm open to suggestions on a PLM header.
- Replace the ECU. The current P73 isn't the right ECU. I don't really understand what's going on because the car is OBDI, so is there a jumper harness maybe? I know the two can't mate up without some sort of modification. I don't like things to be hacked, which the harness appears to be, so I'm thinking of replacing it with a Rywire harness and getting a Phearable ECU. This is outside of my realm of expertise, so suggestions are welcome.
Other than that, I think I'm pretty close with this car. New tires, brake rotors, and other small things are on the horizon as well... but nothing too ground-breaking. Thanks in advance for the help.
Stancetard Hate Monger
Re: Practical Fun: 1998 Civic Sedan GS-R
Exhaust- Apexi ws2, hands down. Quiet, good quality. Can't beat it.
Header- oem ITR. Increased performance over stock, oem quality.
Ecu- post a picture of what's going on there. Classic option is an OBD1 conversation harness with a chipped p28.
I'm not good with identifying wiring and ECUs, so you'll have to talk real slow-like on this one. I was originally thinking of going with a Phearable ECU, with the Rywire harness, as mentioned earlier. What are you guys thinking? I don't even know exactly what I have, haha.
Thanks for the help and input!
H motors is high on the header. I got beaten to one locally for$75 by an hour, just have to keep your eyes open for a deal. Yonaka exhausts are pretty decent, have heard issues about baffles coming apart and rattling from Honda guys. Your ECU is obd-2
. Any chipped ECU will be OBD1, which will require an adapter harness. They're cheap and plug into your existing engine harness at the ECU plugs, no wiring necessary. The reason to do this is that even with a simple basemap, you will have an increase in power. A couple hours on a Dyno can actually get you 10-25hp, in freak situations even more.
just caught that it is a gsr motor, running a type-r ecu. not ideal... different cam profiles, intake manifold is way different, etc...
header length will require some research on your end. i don't see where the car is obd-1, even the engine itself is from an obd-2 car. yes, to dyno TUNE the car, you'll need a socketed ecu, with software of your tuner's choice. since obd-2 ecu's are not "chippable", you'd need to pick out an obd-1 ecu and use an adapter harness so it'll plug and play.
Moderator
I've always found it worth it more to get the quality exhaust with the right baffling. WS2 is just fine. Even the OEM stock mufflers weren't stock, just a slight grey. You can always also high heat ceramic coat the exhaust to whatever you need, but I'd have to say no on the Yonaka. I think you want to validate the Yonaka choice, but na, WS2 all the way.
Another option to qiet down the exhaust without replacing the entire system.
get this:
http://www.apexi-usa.com/store/index.php/exhaust/universal-mufflers/ws2-muffler-universal-na-60-5mm.html
and
this;
https://www.amazon.com/Vibrant-1141-Ultra-Quiet-Resonator/dp/B000E3VHWI
get muffler shopt to cut, bend, and weld those in to your existing set up.
it will qiet it down more.. u still get the quality of both parts..
get this:
and
this;
get this:
get this:
yes, the timing, fuel curves, etc are all way off. stoneage tuning technology got this guy 26whp on a gsr- black smoke? need to fuel tune i/h/c/e ? - Page 2 - Team Integra Forums - Team Integra
What brand resonator and "turbo muffler" do you have right now? I am a big fan of magnaflow. High quality and low price. For the best bang for the buck, maybe just adding an additional magnaflow resonator could get you the sound that you are after. Do you still have a catalytic converter?
Lift your car in the air and see if you have room for an additional resonator somewhere. The longer the better, you can get a 4inch round/ 2.5" diameter magnaflow resonator in 12, 18 or 22 inch length. Obviously 22 in being the most effective.
Probably the wrong terminology, but it's a Magnaflow 53956 (see hyperlink). It didn't change the sound at all, but my exhaust doesn't smell like it used to. Unfortunately, I couldn't fit anything bigger because there is a flex pipe in that region.
For reference, here is a list of all the maintenance I've done on the car (I'm a little OCD):
GapxGuy
12-03-2003 03:21 PM
Bror Jace
50
11-30-2002 07:09 AM
