power window motor
power window motor
Okay this is for a 95 coupe. Right now my window motor seems like it's about to give up on me and die and then at times it seems fine and some times it'll go up slowly. But just woundering would it be possible to swap motors with a newer year like 96-00 window motor or no? Or just need some oil to the motor? Thanks
you can try lubing up the window tracks, but most likely your motor is going out on you, and i dont believe EKs are the same as EG but i could be wrong
Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">most likely your motor is going out on you, and i dont believe EKs are the same as EG but i could be wrong</TD></TR></TABLE>
Anyone else????????????????
Re: power window motor (hatchi)
so if I try lubing it and if it dies on me what are my opions then? No window/ power window unless I buy a motor from junk or somthing to replace it? OR is there anybody that makes "newer motors" for this kind of situation. Most likely junk eh? All right thanks, will have to do.
Dub C
10-08-2010 05:49 PM
