Is it possible to fry a computer this way?
te 3 sensors that having the exact same lips...i believe its the IACV a Temp sensor and maybe the TPS? b18 GSR in a 2000 SI...is it possible to fry the computer if those sensors arent in the correct spot?
1 Post
Re: Is it possible to fry a computer this way?
TPS / MAP/ IACV/ PURGE VALVE i burnt my ecu this way and know a few people whos done the same... doesnt affect the ecu function just smells. you wont pass smog "emissions" with that ecu .
Seagull Management
IIRC swapping the IACV and IAT connectors just fries the IAT sensor. It's swapping the IAT and evep purge plugs that burns Q31 as I recall (Q31 is directly related to evap purge)
Q31 can be replaced. OBD2 ECUs have a couple of these on the board. I cannot recall what the numbers are on the transistor. If you feel up to fixing it, I can look at a board for you.
