Is it possible to fry a computer this way?
Old 01-19-2011, 05:52 PM
godlikehatch's Avatar
Default Is it possible to fry a computer this way?
te 3 sensors that having the exact same lips...i believe its the IACV a Temp sensor and maybe the TPS? b18 GSR in a 2000 SI...is it possible to fry the computer if those sensors arent in the correct spot?
Old 01-19-2011, 05:54 PM
93egSLEEPER's Avatar
Default Re: Is it possible to fry a computer this way?
Highly unlikely. The car will not run and throw codes.
Old 01-19-2011, 06:11 PM
owneyboy's Avatar
TPS / MAP/ IACV/ PURGE VALVE i burnt my ecu this way and know a few people whos done the same... doesnt affect the ecu function just smells. you wont pass smog "emissions" with that ecu .
Old 01-19-2011, 06:12 PM
Mazdaholic's Avatar
in obd1 ecu's, if you swap the IAT and IACV plugs, you can burn out the q31 transistor in the ecu.
Old 01-19-2011, 06:52 PM
Seagull Management
94EG8's Avatar
IIRC swapping the IACV and IAT connectors just fries the IAT sensor. It's swapping the IAT and evep purge plugs that burns Q31 as I recall (Q31 is directly related to evap purge)
Old 01-19-2011, 07:21 PM
NotAJDMFanBoy's Avatar
Q31 can be replaced. OBD2 ECUs have a couple of these on the board. I cannot recall what the numbers are on the transistor. If you feel up to fixing it, I can look at a board for you.
Old 01-19-2011, 07:53 PM
Mazdaholic's Avatar
Yes sir, you are correct; was thinking one thing and typing another
BTW, the part number for the q31 is 2SD1780, if needed.
thenoxus1
Engine Management and Tuning
10-17-2011 07:49 PM
FlatBrokeHatch
08-09-2009 10:40 PM
killrB
02-25-2008 07:28 PM
B18C_EJ8
03-06-2006 10:41 AM
SixguN
11-23-2005 04:05 AM
Quick Reply: Is it possible to fry a computer this way?
