Crower & Supertech
Old 10-11-2012, 04:55 PM
JDM4mee's Avatar
Default Crower & Supertech
Hi there,,,
does anybody knows if I can run Crower Chromoly retainers (part # 87093) with Supertech Dual Valve Springs ( SPR-H1002D )
Reason I ask is because I need them for a DD that will be running Skunk2 Tuner 2, and I donīt want use the Titanium ones on this build up.
I searched and found that Supertech ### will handle the max lift of 12.4mm, but I want to use Chromoly retainers for durability...
Thanks
Old 10-11-2012, 04:56 PM
been there done that
doood's Avatar
Default Re: Crower & Supertech
supertech makes steel retainers for their springs. that's what i'm running.
Old 10-11-2012, 05:00 PM
JDM4mee's Avatar
I did see Supertech makes them as well.... the reason I went ahead and search for an alternative was because I did not find the specs of the supertech steel retainers. On the other hand, I found all the info about the Crower ones...
Are you happy with your current set up ?
What cams are you running?
Old 10-11-2012, 05:23 PM
doood's Avatar
what specs are you looking for?
i have a k series so it wouldnt apply to you too much. i will say they are very noisy even with the valves adjusted to oem specs.
tunerraceteam
67
06-22-2007 03:09 PM
precisionelite
05-01-2006 12:39 PM
Pearl Crx
03-06-2005 05:21 PM
paulzy
08-26-2002 05:32 PM
Quick Reply: Crower & Supertech
