please help with smoke in civic lx
Old 08-21-2007, 05:26 AM
integra dave's Avatar
Default please help with smoke in civic lx - MAJOR UPDATE AND BIG PROBLEM NOW!
before i start i found this thread https://honda-tech.com/zerothread?id=2062137
my car is a 1998 civic lx 4 door. i dont have anything crazy on it just an intake. a friend told me yesterday that the car was blowing smoke when i "gunned" the car say to go up a hill or spped up. This morning I checked it by parking the car and revving the car. I discovered that it does indeed blow smoke. see for yourself at http://www.audioinnovationsny....e.mp4
according to the thread i found some people said it could be a head gasket or burning oil etc...... any help would be greatly appreciated
thanks
Modified by integra dave at 11:23 PM 8/23/2007
Old 08-21-2007, 05:38 AM
Default Re: please help with smoke in civic lx (integra dave)
ttt
Old 08-21-2007, 07:46 AM
can anyone please help on this?
thanks
Old 08-21-2007, 09:03 AM
steve_s's Avatar
ttt
Old 08-21-2007, 09:17 AM
Shimakid12's Avatar
does it smoke on start up? it could possibly be bad valve seals. If the seals are bad then oil will leak past the seals and burn up, causing the smoke from the burnt oil to escape through the exhaust valve, which would smoke out of your car like a ****, espeacially on start up in most cases. Just one of a million possibilities.
Old 08-23-2007, 02:25 PM
Default Re: (Shimakid12)
today i drove from tampa to orlando and back - about 300 miles..... i started with 4 quarts...... when i got back the oil light was on.... it seem slike the car is burning a lot more oil than originally thought..... my major problem is that i have a FL to NY drive planned for this sunday and im scared shitless. last thing i need is to have this car die on me on the way up. i plan to have oil with me but what could this issue be???? any additional help would be appreciated.
thanks
Old 08-23-2007, 03:24 PM
4bangin92's Avatar
Default Re: (integra dave)
unless this is high priority drive, i wouldnt take ur car in that condition. if it is, take extra oil with you, and remember to make a lot of stops to add oil.
Old 08-23-2007, 03:42 PM
Default Re: (4bangin92)
yah this is a high priority trip and i have to take that car. i plan to take oil with me ...... i guess my question is what the hell is causng this ???
Old 08-23-2007, 04:31 PM
ttt
Old 08-23-2007, 04:35 PM
Stouts 'n' Scotch
wiZCo's Avatar
For some reason I can't play the video.
What color is the smoke? Do you have oil in your coolant or milky oil? Have you done a compression or leakdown test yet?
I reaaaaallllly wouldn't drive it to NY if I were you until you get this problem figured out. Oil is like blood. You can't live without blood right?
Old 08-23-2007, 06:23 PM
Default Re: (wiZCo)
the oil is white - only seems to blow out when i hit the gas hard say to speed up or pass another car. the car is not overheating and it actually runs quite well. im just worried about this drive because i have no other choice. i need to take this car. once im there i can deal with the issue head on...... i just need to get there. any ideas?
Old 08-23-2007, 06:25 PM
nix94delsol's Avatar
my brothers car does that, hes got bad valve seals
have your head checked...the one on your car
Old 08-23-2007, 06:29 PM
Default Re: (nix94delsol)
thank you nix. any other ideas guys?
Old 08-23-2007, 08:14 PM
Stouts 'n' Scotch
wiZCo's Avatar
Sounds like a blown HG to me, although it really hard to tell over the internet without compression #s.
Is there oil in the coolant? The last time I had a blown HG it would smoke only at high RPMs, no overheating or stuttering. The only way I was able to find out for sure was seeing oil in my coolant.
Old 08-24-2007, 10:27 AM
Default Re: (wiZCo)
i havent done a compression test but i know from experience that a blown HG typically results in a lot of overheating etc. since my car isnt doing any thign else but burn oil i am a little hard pressed to think it's a HG.
bradabu
03-07-2012 06:45 PM
ACrite3404
06-27-2008 02:31 AM
EvilCamaroSS
10-07-2005 04:24 PM
Boost2NA
12-20-2003 10:46 AM
Nfurno
09-14-2002 10:58 PM
Quick Reply: please help with smoke in civic lx
