PLEASE help me fix my window guys!
hey guys i had a bad ground in my passenger side window and it would only work when the door was closed because the previous owner did not put the rubber back on the harness in between the door/hinge....and i took the door apart ,tried to fix it....but the passenger window stopped working COMPLETELY.....then i shook the harness and it went up....and now it wont do anything.......AND my driver side window was fine and untouched....but when i opened up the passenger side window, the driver one stopped working and wont go up.....PLEASE HELP IM GOING CRAZY!!!
Re: PLEASE help me fix my window guys! (gtowni3)
if there is anyone in new york or nj....near nyc i guess...that can help me fix this in person...ill give you cash....PLEASE HELP!!!!!!!!!!!!!!
If the switch is unplugged or not making a good connection, or if the wires leading to it are broken or cut in half, neither window will work. check you plugs for corrosion and carefully inspect any splices in the wires.
