please help brakes tend to sink....
my brakes tend to sink from time to time.. is my ABS messed up or do i need to bleed it again...please help
Re: please help brakes tend to sink.... (project209)
you probably have air in the system or are leaking fluid....look for any leaks around the wheels and check the fluid level. if you dont see nything bleed your breaks
Re: please help brakes tend to sink.... (H22Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">you probably have air in the system or are leaking fluid....look for any leaks around the wheels and check the fluid level. if you dont see nything bleed your breaks </TD></TR></TABLE>
could also be bad fluid.contaminated etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project209 »</TD></TR><TR><TD CLASS="quote">my brakes tend to sink from time to time.. is my ABS messed up or do i need to bleed it again...please help</TD></TR></TABLE>
look around the brake hoses and MC for leaks. if there are no leaks, booster could be going out. what year is your civic?
