help please
help please
i took off the valve cover on my civic had it off for a couple of days to paint it ant then and also to chang the seals i covered the engine and stuff i put it back on every thing was where it is supose to be even put the ground back on tried to start it and all i here is the starter turning over it wont turn the crank shaft or nothin some one please help me thanks in advanced
ok, well first clean your ground wire make sure there is not dirt on anything around the o ring, next check your plugs and wires if you changed the seals then you had to mess with them get back to me after that. was it having any problems before that,
Re: help please (tcs8ter)
naw it wasnt havin any problems before excet for the major oil leak where the spark plug was ill clean the ground in the morning
naw i finally got it started and the leak was worse the there was a spark from the alternator and the baterry fuse blew then when i bought a new fuse it started back up an the altenator did charge the battery and its brand new this sucks and the leak is still there even though i used silicone
oh man sorry to hear, i dont know exaclty what happen, I dont understand what this had to do with your alternator, are you sure its the alternator or the battery, I am tech lost, because i dunno what happen sorry to hear about the bad news let me know what happens
deric030306
06-16-2011 12:05 AM
Coolcat55
10
05-18-2007 07:36 PM
egriffith45
08-19-2006 08:56 PM
