PCV help
PCV help
How do I access the PCV to replace it? I know where it is, but I'm not sure how to get to it since it's sort of under the manifold. Can i just pull it through the cut out in the IM? Is there a DIY for this?
This is on a D16Y8
This is on a D16Y8
Re: PCV help (SOHC_MShue)
I had it jacked up to do some other stuff, but I couldn't really get to it. I suppose I'll try that again. I had so much other work to do on the car that I only spent about 5 minutes trying to access it. I figured I'd try again some other time. The service manual wasn't much help, it just shows you where it is and says remove it.
1 Post
Re: PCV help (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">I had it jacked up to do some other stuff, but I couldn't really get to it. I suppose I'll try that again. I had so much other work to do on the car that I only spent about 5 minutes trying to access it. I figured I'd try again some other time. The service manual wasn't much help, it just shows you where it is and says remove it. </TD></TR></TABLE>
Remove you intake manifold and you will be able to reach it without a problem. Or do it the lazy way and get a set of bent needle nose pliers and try to reach it that way.
Re: PCV help (JDM-EGGROLL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EGGROLL »</TD></TR><TR><TD CLASS="quote">
Remove you intake manifold and you will be able to reach it without a problem. Or do it the lazy way and get a set of bent needle nose pliers and try to reach it that way.</TD></TR></TABLE>
I'd need a new gasket if i took the mani off, right? I may just try the pliers...
