Passenger is axle is popping out help!
Let the g.f take the car out the other day and hit a damn curb lower control arm was screwed also the part where the axle slides into the tranny the part inside the boot popped out. I replaced the lower control arm and the axle. the top of the tire is pointed out past the fenderabout and inch out can caster and camber be the screwed up from that. Also the axle is slipping out.When its in all the way i cant even turn it by hand whats up with this? Do ex's have abs its a 97 ex.
Re: Passenger is axle is popping out help! (Frost7177)
ok so look at your caliper if there is 2 hoses going to it than you have abs
if only one than well you don't have abs. at least that's my understanding.
i don't and only have one line.
as far as your axle problem...
there is something bent or way out of line.
go and get an alignment and you will at least know where you stand
Firestone has a lifetime alignment for like $160
it's not the best but i can now get an alignment every day if i want to.
Re: Passenger is axle is popping out help! (95jeremie)
the axle is popping out i cant even drive it there. When i try to push it in all the way it feels like something is in the way.
Re: (Syndacate)
when you put the axle in you have to get it past the spring clip on the axle stub. ive never been able to "push" it in place, takes more of "jab" to snap it in.
