sidemarker wiring
sidemarker wiring
ok i searched and no one knew what they were talking about.
i wired up my sidemarkers today and everything was fine. but tonight i noticed that they are lit up constantly with my corner lights. i only want them to blink. so what color is the wire that i should tap in to? thanks
Re: (91sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sleeper »</TD></TR><TR><TD CLASS="quote">btw i tapped into the green wire which is obviously the wrong one. so how do i just make it blink.</TD></TR></TABLE>
i can't recall off hand which wire it is, but just take a wire tester and figure it out. it shouldn't take you more than 5 minutes...
but if by tomorrow you haven't done so, i'll check which wire i tapped into and i'll let you know...
Re: (GroundZer0 336)
well u can do it however u prefer. sidemarkers only come on when u turn ur corners in japan. the way u wire them is..... tap into the green wier, n then ground the black wire anywhere. thats how i have it, n it work. AMUST for JDM look.
bump
bump
