P1508 and bucking- tried everything
Old 09-13-2012, 06:38 AM
themow12's Avatar
Default P1508 and bucking- tried everything
97 HX 5spd. Bone stock 220k
Got code P1508 along with surging issues when off throttle and very low idle-5-600 low to the point where the its not smooth when sitting. I replaced my IAC with one from the junkyard and having the same exact issues. Bled coolant to make sure all air was gone. Checked for vac leaks and couldnt find anything. Cleaned throttle body.
I do have a hairline crack in the header but its small and has been there for a while. You can not hear any exhaust leak at all. I planned on replacing it when it got loud but its got the cat attached so its expensive. I have reset the ecu and relearned idle multiple times. I have googled for days and am not coming up with much. Any help is much appreciated.
Old 01-19-2014, 05:38 AM
cjames241's Avatar
Default Re: P1508 and bucking- tried everything
Did you ever figure this out?
bdonahue
03-21-2016 08:20 AM
Efjams24
07-22-2012 02:00 PM
fronomo
08-28-2007 03:56 PM
wreckedmyteg
07-15-2005 06:00 AM
UNKNOWN_MEMBER
06-27-2005 08:15 AM
Quick Reply: P1508 and bucking- tried everything
