Cluster Problem..Please HELP!!
Old 04-04-2010, 07:07 PM
CiToDc2's Avatar
Icon2 Cluster Problem..Please HELP!!
THANXZ H-T I GOT IT 2WERK!!!
CiToDc2's Avatar
Default Re: Cluster Problem..Please HELP!!
Help me out .....
Old 04-04-2010, 07:16 PM
CiToDc2's Avatar
Old 04-04-2010, 07:21 PM
CiToDc2's Avatar
92lxsleeper's Avatar
should just plug in and work... find the tach signal wire and check it at both ends for continuity, and check the resistance of the wire while reving the engine to see if the impedance changes with the rpms.
Old 04-04-2010, 07:29 PM
CiToDc2's Avatar
thanks 4 the info ima check in da morning i just want 2 get a bunch of opinions so i can try all of them in the morning...
Old 04-04-2010, 07:33 PM
CiToDc2's Avatar
Old 04-04-2010, 07:36 PM
CiToDc2's Avatar
Old 04-04-2010, 07:50 PM
CiToDc2's Avatar
Old 04-04-2010, 11:23 PM
nathan_559's Avatar
i had the same problem..i tried a buddy's 96 ex cluster into my car to see how it'll look and the rpm gauge didnt work, but on his car it was perfect..
i checked all the wiring to my cluster and everything looked good..
i ended up connecting a little tach and puttin it right behind my steering wheel..
well...if all else fails run a wire straight from the blue(signal wire) from the dizzy to the cluster wire where the tach signal wire is and that should work for sure..
if u need more info hit me up..
Old 04-04-2010, 11:51 PM
EracerUgone's Avatar
Should be plug and play and should work, if not then not sure
Old 05-24-2010, 04:11 AM
CiToDc2's Avatar
thanxz man it werk 2 da dizzy...
GhostRidaz
12-24-2010 07:52 PM
Wazup
12-04-2007 05:09 PM
civiccpedx
05-18-2007 06:56 PM
bubbakrip
03-29-2006 09:37 PM
89dohcEF
09-07-2005 10:44 PM
Quick Reply: Cluster Problem..Please HELP!!
