P0135 Code, Testing Results and ?'s (solved)
1998 Civic EX (D16Y8) coupe stock. A/T. 148k
Have a P0135 CEL and followed this: Part 1 -How to Test Trouble Code P0135 (1995-2000 Honda 1.6L) to check it.
Results:
Fuse 15 intact and not blown.
BLK/YEL reads 12v.
BLK/WHT reads 4.3v..( should be 12v).
o2 sensor pins 3 & 4 reading 13.6 ohms (acceptable range is 10-40 ohms).
Live in Florida so no worry of emissions check.
Is there a fix or bypass for:
"If your multimeter still doesn't register the 10 to 12 Volts DC, then the most likely cause of this missing ground is an ‘open’ in the BLK/WHT wire between your Honda Civic's PCM harness connector and the O2 sensor's harness connector."
Should I wrap the harness near the bracket with electrical tape anyway to prevent possible fuse blowing?
Results:
BLK/YEL reads 12v.
re: P0135 Code, Testing Results and ?'s (solved)
How to do that?
I measured resistance across C&D of oxygen sensor which read 13.6 ohms.
Are these harnesses connected correctly under the intake manifold? Is the gray piece that is connected to the blue piece just a cap?
Should I wrap electrical tape around them?
Side question if permitted...Is the tension on my timing belt correct or too tight?
https://www.youtube.com/watch?v=1u0N...ature=youtu.be
Will update timing belt to this thread: https://honda-tech.com/honda-civic-d...ilure-3250014/
Fish Twig
Sup "dad".
Anyways when tensioning the best you need to align all timing marks (crank and cam gear), loosen the tensioner 1/4 turn, turn the crank 3 teeth and then tighten the tensioner. DONE, BEER, IMAGINATION HIGH-FIVE.
aejeffor
10-03-2011 10:07 PM
