P0133 02 Sensor Issues
Hello Everyone,
I've been having this code P0133 code (O2 Sensor Circuit Slow Response Bank 1 Sensor 1) come up so I changed the 02 Sensor with a Bosch 02 sensor from Advanced Auto Parts and also changed the Distributor.
However, my car is still having issues with "losing power" and "high idling" while I am trying. (I have two cars so I drive the other one currently) My personal mechanic has been busy and can't take a look at it until next week. What else can I do? What do you guys think? I've read on other posts that it could be the catalytic converter?
I drive a 1997 Civic LX and recently did an automatic to manual swap. Note mentioning that a P0453 and P0450 code as well for the EVAP sensor, my mechanic thinks it is a leak.
Re: P0133 02 Sensor Issues
I'm not sure about the cat, I was reading other threads about the P0133 code issue and it seemed to come up frequently.
Well, I took the distributor and 02 sensor from the junk car that I used to do the manual swap, both of them were bad so I had to replace them.
I have an aftermarket catalytic converter/exhaust manifold so the downstream 02 sensor is elsewhere. So I believe I did not improperly installed the upstream 02 sensor.
rasta420
06-08-2007 01:59 PM
