P/S pump I.D
P/S pump I.D
hi, i bought my 97 ex with a b16 with p/s. Now it have a ls vtec turbo with the same head and p/s pump, recently it start to spit the belt at high rpm's.
Checking the pump i realize the damper is shaking badly.
I try one of a d16y8 (not fit)
find one from ls 97 (different line)
What's the difference between integras pumps and how can i I.D. my old one.
thanks
carlos
thanks
carlos
Seagull Management
Re: P/S pump I.D
If you post a pic of the pump I can ID it for you. Generally speaking though you need a '98 - '01 Integra or '99 - '00 Civic Si pump for a B-series in a '96 - '00 Civic. This works 99.9% of the time.
The only real exceptions are B20s can use the B20/CR-V PS pump and if a '92- '95 Civic/\94 - '97 Integra feed line was used the pump must come from either of those two vehicles.
Re: P/S pump I.D
I thought all b maybe even D series ps pumps were the same(cross-compatable) afaik either the top or bottom bracket(s) need to be switched.
Seagull Management
Re: P/S pump I.D
They aren't. The end of the feed line where it bolts to the pump (along with the pump itself) is different between '92 - '95 Civics/'94 - '97 Integras and '96 - '00 Civics/'98 - '01 Integras/'97 - '01 CR-Vs. The '96 - '00 Civics (except '99 - '00 Si) and CR-V use a complete different style pump and bracket as well.
hybridej7
07-22-2005 06:31 AM
