P/S pump I.D
hi, i bought my 97 ex with a b16 with p/s. Now it have a ls vtec turbo with the same head and p/s pump, recently it start to spit the belt at high rpm's.
Checking the pump i realize the damper is shaking badly. I try one of a d16y8 (not fit) find one from ls 97 (different line) What's the difference between integras pumps and how can i I.D. my old one. thanks carlos |
Re: P/S pump I.D
If you post a pic of the pump I can ID it for you. Generally speaking though you need a '98 - '01 Integra or '99 - '00 Civic Si pump for a B-series in a '96 - '00 Civic. This works 99.9% of the time.
The only real exceptions are B20s can use the B20/CR-V PS pump and if a '92- '95 Civic/\94 - '97 Integra feed line was used the pump must come from either of those two vehicles. |
Re: P/S pump I.D
I thought all b maybe even D series ps pumps were the same(cross-compatable) afaik either the top or bottom bracket(s) need to be switched.
Re: P/S pump I.D
Originally Posted by B_Swapped93
(Post 48735281)
