Overheating....
Old 03-23-2004, 05:43 PM
Dveloped's Avatar
Default Overheating....
about a week and a half ago my gf's ej1 started overheating. Since then we found a crapped out water pump, radiator, and thermostat. We changed the radiator and waterpump for new ones, took out the thermostat cause we're in hawaii and we dont need it, and all the fluid levels are topped out. After all that it still overheats but takes about 10 minutes to do so and from then it (the needle) keeps jumping up and down. Theres no water in the oil, no coolant leak in the exhaust, no loss of power, and runs great (except the overheating) so I dont think theres a blown headgasket.
wtf is wrong?
Old 03-23-2004, 06:12 PM
Dveloped's Avatar
Default Re: Overheating.... (Dveloped)
Old 03-23-2004, 06:16 PM
JDMlyfestyle's Avatar
might have gotten a bad thermo. but my guess would be the thermostat. when u replace it dont get auto zone, pep boys, or advanced auto thermos go OEM or aftermarket
Old 03-23-2004, 06:17 PM
CoolKat's Avatar
Air in the coolant will also make the needle fluctuate, try bleeding the coolant and see if your problem still persists.
Old 03-23-2004, 08:51 PM
Dveloped's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">might have gotten a bad thermo. but my guess would be the thermostat. when u replace it dont get auto zone, pep boys, or advanced auto thermos go OEM or aftermarket</TD></TR></TABLE>
i took out the thermostat completely
Old 03-23-2004, 08:56 PM
z6
z6's Avatar
Default Re: (Dveloped)
YOU SIR ARE A GOOF..where you live dosnt change if you need a thermostat or not...clearly you dont even know what it does(if you think you dont need one)....put the damn thing back in
Old 03-23-2004, 09:29 PM
Y in the hell would u take out the thermostat completely.
your thermostat lets the hot coolant out of the eninge while the fresher cooler coolant comes into the motor. it cycles it. when u take out the thermostat its just a constant flow and it does not allow the radiator enough time to cool down the coolant. so do ur self a favor and put your thermostat back in
Old 03-23-2004, 09:46 PM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dveloped &raquo;</TD></TR><TR><TD CLASS="quote">
i took out the thermostat completely</TD></TR></TABLE>
LOL ( )
Put a NEW, OEM one in and get back to us.
Old 03-23-2004, 09:54 PM
New User
Civic4doors's Avatar
Default Re: (sickSOLvtec)
Yea you need the thermostat in so that the water will have enough time in the rad to cool off.so i would try a new thermostat and see if that helps.
Old 03-23-2004, 10:08 PM
RangerDan's Avatar
Default Re: (Civic4doors)
What they said.
In addition to this the headgasket can be ruled out only after a comp. test. My Nephew ran around with the same problem your describing to the tee. I told him check your headgasket and he put it off until he came up and visited one week.
Well to make a crappy story shorter... new headgasket...no more problems.
Good luck!
Old 03-23-2004, 10:23 PM
Colorado <3
918-Hatch's Avatar
how did it turn out? ur fan work?
Old 03-23-2004, 10:31 PM
eddiecut's Avatar
Default Re: (918-Hatch)
no thermo would make it run cooler not hotter
Old 03-24-2004, 03:34 AM
specv5150's Avatar
Default Re: (RangerDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan &raquo;</TD></TR><TR><TD CLASS="quote">What they said.
Good luck!</TD></TR></TABLE>
Yeah when my headgasket blew I didnt have any of the symptoms besides overheating when the A/C was on, next thing I know boooooom.
raider1qaz
02-21-2013 07:06 AM
ADIZZLE08
Honda Civic (2001 - 2005)
13
05-11-2010 08:15 PM
greenlikematt
10
07-22-2008 06:30 PM
PureEF8
07-01-2006 03:20 PM
Cuong-nutz
10
11-02-2005 10:21 AM
Quick Reply: Overheating....
