Camber Kit...
Old Feb 9, 2007 | 10:01 PM
guero2craze's Avatar
Default Camber Kit...
I just drop some konis/HR sports and my camber is out lika 1.8...wat camber kit would you recommend...i need all four and am not lookin for an expensive one but one wit good quality...
Old Feb 9, 2007 | 10:05 PM
hks369's Avatar
Default Re: Camber Kit... (guero2craze)
get like skunk2 or omni power in the fron and for the back get a omni power shim kit its pretty much bigger bolts
Old Feb 9, 2007 | 10:13 PM
Default Re: Camber Kit... (hks369)
wat about the brand blox...
Old Feb 9, 2007 | 10:22 PM
ejmatzell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guero2craze &raquo;</TD></TR><TR><TD CLASS="quote">wat about the brand blox...</TD></TR></TABLE>
i know the company is pretty cheap, not sure about the camber kit in particular though. my vote goes to skunk2
Old Feb 10, 2007 | 02:31 AM
1158's Avatar
Go ask this in the wheel/tire or suspension forums and they'll tell you, camber doesn't kill tires...toe is what kills tires.
Personally, I wouldn't worry about it. My camber is about the same and I'm not having any problems because I had the toe set correctly..
Old Feb 10, 2007 | 08:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
-1.8 will be perfectly fine without a camber kit, just make sure you get the tires aligned with toe set to exact factory specs.
guero2craze
Suspension & Brakes
Feb 22, 2007 09:53 AM
peel17
Suspension & Brakes
Nov 11, 2005 01:41 PM
BADGUYNY
Oct 19, 2003 05:50 PM
Shorty C
Jun 24, 2003 12:24 PM
