ok now what is the problem i have no clue
ok i finally got the check engine light done now the one problem i am having is when i start my engien i am getting a whining from the lower part of my timing belt area could it be my tension on my timing belt could it be the tensioner itself what else could i look for thanks guys
Re: ok now what is the problem i have no clue (mrnice1058)
I would unhook all your accessory belts, one at a time, and each time you remove a belt start the car and listen for the noise. I had a similar noise, I thought it was my water pump, turned out to be the bearing in the A/C tension pulley.
Re: ok now what is the problem i have no clue (spoonek9)
ahhhhhhh thanks i thought about it but i didn't think it would be the problem i will check that tomorrow thanks for you help
onesloweg
03-28-2007 02:41 AM
