Ok I CANNOT get the drums off my 99 civic.
Old 04-29-2003, 11:36 AM
sivik2nr's Avatar
Default Ok I CANNOT get the drums off my 99 civic.
I've been trying for the last hour. I cannot get the rear drums off my 99 civic. I've tried everything, and did searches... is there something i'm missing? I've tried pounding on it.. I've tried prying on it.. I've tried the screw in the little hole. I dont' get it. ( no the parking brake is not on ) It spins freely, but no dice.
Can anyone help?
Old 04-29-2003, 11:40 AM
Kid1320's Avatar
Default Re: Ok I CANNOT get the drums off my 99 civic. (sivik2nr)
use longer screws and use two screws. screw both of them in as evenly as possible. this should work
Old 04-29-2003, 11:43 AM
sivik2nr's Avatar
Default Re: Ok I CANNOT get the drums off my 99 civic. (Kid1320)
Ok i'll try to find something. I only had that one screw, but i'll try to find another...and give it another shot.
If not i'll be back.
Old 04-29-2003, 11:44 AM
Luserkid's Avatar
Get WD-40 spray the hell out of where the lugs and drum meets. Then get a small mallet or big hammer and hit the drum as hard as you can and a little on the lugs (not to hard). That works or me when there stuck. Good luck.
Old 04-29-2003, 11:45 AM
Kid1320's Avatar
Default Re: Ok I CANNOT get the drums off my 99 civic. (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Get WD-40 spray the hell out of where the lugs and drum meets. Then get a small mallet or big hammer and hit the drum as hard as you can and a little on the lugs (not to hard). That works or me when there stuck. Good luck.</TD></TR></TABLE>
rubber mallet please
Old 04-29-2003, 11:47 AM
ejprimo's Avatar
did you remove the big 32mm nut behind the big metal cap on the center?
Tony Starks's Avatar
Spin the drum while pounding it with a RUBBER mallet. They will come eventually. And hit that thing, don't be gentle!
Old 04-29-2003, 11:57 AM
sivik2nr's Avatar
Default Re: Ok I CANNOT get the drums off my 99 civic. (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the big 32mm nut behind the big metal cap on the center?</TD></TR></TABLE>
yeah, i took off the 32mm nut..
I dont' get it... it spins freely and I can jiggle it a little bit , but won't come all the way off..
Mr. Badwrench
boostedcivicsir's Avatar
you should be able to get it off with out removing the hub, that is a last resort. but a good idea. also clean the rust off of the hub right around where the drum sits. it is a bitch but it will come off.
Old 04-29-2003, 12:02 PM
monicle's Avatar
dont listen to any of those other jokers they dont know what they are talking about. if you are just trying to get the drum cover off (thats what i assumed you were talking about) after you take off the wheel there are 2 empty threaded holes between the lugs. get the correct threaded bolts (bolts from the clutch are a perfect fit) turn them in there and the drum will come right off so you can get to the pads and whatever else you are trying to do. if you use those bolts i dont thik theres a way you can mess this one up.
Old 04-29-2003, 12:04 PM
ABTDer's Avatar
Default Re: Ok I CANNOT get the drums off my 99 civic. (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to any of those other jokers they dont know what they are talking about. if you are just trying to get the drum cover off (thats what i assumed you were talking about) after you take off the wheel there are 2 empty threaded holes between the lugs. get the correct threaded bolts (bolts from the clutch are a perfect fit) turn them in there and the drum will come right off so you can get to the pads and whatever else you are trying to do.</TD></TR></TABLE>
sorry to burst your bubble but kid1320 above said that already
Old 04-29-2003, 12:05 PM
monicle's Avatar
Default Re: Ok I CANNOT get the drums off my 99 civic. (Drunk-N-Munky)
ah
Old 04-29-2003, 12:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to any of those other jokers they dont know what they are talking about. if you are just trying to get the drum cover off (thats what i assumed you were talking about) after you take off the wheel there are 2 empty threaded holes between the lugs. get the correct threaded bolts (bolts from the clutch are a perfect fit) turn them in there and the drum will come right off so you can get to the pads and whatever else you are trying to do. if you use those bolts i dont thik theres a way you can mess this one up.</TD></TR></TABLE>
Hmm..... I couldn't find any screws to fit the holes. My technique worked fine. Guess I'm a joker.
Old 04-29-2003, 12:13 PM
sivik2nr's Avatar
it's like the drum (cover) is hooked on somehitng. Its starting to come off, but then it just stops..like if there was a lip on there or something and the shoes are hooking it.
I know it's not rusted, that's not the problem..
I'm about to bust out the chainsaw...
Wisconsin Honda Chainsaw massacre!!
Old 04-29-2003, 12:15 PM
ABTDer's Avatar
Default Re: (sivik2nr)
be patient. try to remove the cover evenly so the holes on it wont hit your studs
Old 04-29-2003, 12:16 PM
monicle's Avatar
how long are the bolts that youre trying to use to take the cover off with?
Old 04-29-2003, 12:36 PM
sivik2nr's Avatar
hold on a sec.. i'm uploading a video of what i'm talking about..
had to bust out the Digital 8
Old 04-29-2003, 12:45 PM
monicle's Avatar
damn dude what the hell movie is that from with the japanese chicks face all melting off like that? wierd lookin
Old 04-29-2003, 12:49 PM
sivik2nr's Avatar
Default Re: (monicle)
haah i dont' know I can't remember...
ok I think this should work
click the link, then click download video then when the next window pops up right click , save target as....
Old 04-29-2003, 12:54 PM
monicle's Avatar
aight check it out. at the very beginning of the film the lug on the left and the lug on the right you see the small hole above the one on the left and below the one on the right. you need to find 2 bolts that thread perfectly into those holes. just keep alternating a half turn on each one and itll come right off.
Old 04-29-2003, 12:55 PM
Happyman's Avatar
&lt;34 way discs
And stop grabbing thr dum like its a titty. Get your fingers on the lip.
Old 04-29-2003, 12:57 PM
monicle's Avatar
im leaving work right now ill see if i can find a bolt from your engine bay that you might be able to use for it in about 10 minutes unless you get it before i get home.
Old 04-29-2003, 12:58 PM
sivik2nr's Avatar
alright thanx
Old 04-29-2003, 01:04 PM
sivik2nr's Avatar
alright I found a different bolt and cranked that **** as hard as I could and pop it came loose.
Thanks alot all you guys...
HT rocks
Old 04-29-2003, 01:12 PM
monicle's Avatar
cool no problem. Dont forget to notch that big spindle nut when you put it back on. 135lbs torque btw.
Quick Reply: Ok I CANNOT get the drums off my 99 civic.
