oil pan torque specs
Old 01-16-2008, 01:17 PM
SiR-EJ1's Avatar
Default oil pan torque specs
i have searched it and cant find anything. but does anyone know the torque specs for the oil pan on a b series and the bolt pattern?
Old 01-16-2008, 01:40 PM
Datphan's Avatar
Default Re: oil pan torque specs (SiR-EJ1)
8.7 ft lbs
Old 01-16-2008, 02:10 PM
Reject Papi
jhammond_82's Avatar
Default Re: oil pan torque specs (Datphan)
tight enough so the gasket doesn't leak. but not over tighted. i don't own a torque wrench, so i would guesstimate it.
Old 01-16-2008, 02:20 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datphan &raquo;</TD></TR><TR><TD CLASS="quote">8.7 ft lbs
Edit: above is correct
Old 01-16-2008, 07:23 PM
CAM0FLAG3's Avatar
There is a bolt pattern also, but im not sure what it is... goodluck, make sure to clean those mating surfaces well.
Old 01-16-2008, 07:34 PM
Datphan's Avatar
there is a torque sequence
just tighten up these six bolts first
then work around it
dirtycolombian
11
07-18-2007 01:14 PM
NewtwoHondas
06-25-2006 04:20 PM
JDubya
06-09-2004 03:11 PM
minitec
05-06-2003 04:25 PM
prjctCIVIC
09-01-2001 09:53 PM
Quick Reply: oil pan torque specs
