Oil Pan
Re: Oil Pan (northkai3)
just buy the oem gasket and replace it. You have to take off the trans braces to get the trans access cover out of the way and be careful with the pan bolts the are easy to cross thread and very small dia and do not take much to break or strip.Also only use a small amount of sealent around the hump on the gasket you don't need any anywhere else
Curlybandit
Engine Machining & Assembly
08-13-2018 12:18 PM
deconstruct
06-18-2004 01:00 PM
