Odd Tach Readings
Odd Tach Readings
Hi everyone,
I recently purchased a 1998 Honda Civic CX hatchback to build into a nice streetcar. I picked up a Civic EX cluster with a tach for the car and after installing it the tach is all over the place.
Usally when I start the car the tach goes to to 5,000 and reads from there after letting it warm up it usally comes down to around 1,000 rpm. Also sometimes when I turn off the car the needle drops down to the right side of the tach.
When I first installed the cluster I got a check engine light for the CFK sensor and performed the CFK bypass. This got rid of the CEL but I’m still having the same issues.
I read a couple post with people that had this issue but with no solutions. Has anyone had this issue and found a solution?
The people I bought the car from performed a d series engine swap. The head is a P2A-7 with a ZC block.
Re: Odd Tach Readings
Thanks for your input. I’ll start looking into that. Is there anything in particular that I can do to find out if the problem is either the tach or ICM or the whole distributor?
If the tach reads other than 0 with the key on engine stopped, it is almost certainly the tach head not the ICM or ECU.
I think in OBDII the tach signal comes from the ECU not the ICM.
The problem with buying another cluster is that they're all 20 years old.
I’m looking into getting an Omni tach to replace the one in my car. Does anyone have any experience with it?
I saw a review posted by HT member SHRUGS* on the Omni tach and he seemed pretty happy with it. I have also seen on numerous occasions where people has stated that the stock tach isn’t all that accurate at high rpm.
