obd2b to obd1 help!!!!
soo i have a 2000 itr and i recently totaled it so ima put my b18c5 in my 93si and i was wondering wat i would need to convert my c5 to obd1? would i jus need the obd1 dizzy and alternator? and injector wires and splice on the obd1 connectors? any input would help thanks
I'm not Rick!
Re: obd2b to obd1 help!!!!
yes and yes and if you wanted to
your injector plugs just use a razor and cut the nub off he injector and then itl plug in..
but you should definetly do more searching
thats what i was guna do in the first place but i tried to jus take out the harness from the motor but a bunch of other wires are in the harness like abs and headlight harness..or would the engine harness plug into the connectors on the shock tower of my eg
Mr. Badwrench
the engine harness is completely isolated from the rest. just the plugs at the shock tower, and the other plugs near the master cylinder.
luckily obd1 and 2 dizzys have the same guts basically.
not obd0 and 1? thats where you would need to change.
myEK=slow
11
08-21-2006 08:20 PM
