obd1 to obd2
obd1 to obd2
Will my wire harness plug n play with obd 1 motor.
I have a obd 2a ecu and obd 2 wiring harness.
my alternator distributor fuel injectors plug on obd 2 is different then the obd 1.
what will work on b18c1 head? what kind of vtech solenoid controller? Dont have one need one? what to buy?
should I go to obd 1 or stick with obd 2. What to do. dont have obd1 ecu nor wiring harness. or keep wiring and put obd 1 ecu.
Needing help so I can have a car to drive. but i wanna do it right. It a 1999 honda civic ex car. I putting a GSR in there.
Technical Hero
Re: obd1 to obd2
List your year make model. Alternator, injectors, distributor will not plug and play. You'll have to wire up VTEC, knock and IABs. Depends on your state emissions whether an obd1 or obd2 ECU will pass. Don't buy a VTEC controller.
Re: obd1 to obd2
you can either change the injectors or do what I did and buy the adapter harnesses from rywire. you'll have to get a diff alternator. and I'm pretty sure rywire sells a Vtec sub harness too. just need to pin it to your ecu plug.
Canadian_EF
09-11-2012 08:36 AM
