Obd1 b18b1 swap CEL
Obd1 b18b1 swap CEL
I swapped an OBD1 b18b1 into my 97 DX hatch using an EX harness and an OBD2a > OBD1 jumper harness and a p75-a01 ecu, it runs great, It doesn't smoke or burn oil at all! My only gripe is that when I put my key in and turn it to the on position, the CEL comes on and then goes out at the same time that the fuel pump finishes priming. When I start the car it takes about 2-3 seconds until the CEL comes on and then it just stays on solid. Any ideas?
Re: Obd1 b18b1 swap CEL
Its showing 3 quick flashes first and then 5 slow ones. So thats a code 3 (map sensor) and a code 41(primary o2) Correct? Also my SRS light is blinking when I have the service connector jumped, but normally it is on solid, Ive tried to reset the SRS light in the past but to no avail. Video of said codes
Yea, I went through and edited my post and forgot to change the initial flash numbers. it is 3 half second flashes followed by 4-1 second flashes and 1 half second flash. As far the the SRS goes: First I am getting 9 long flashes followed by 2 short ones. Then I am getting 6 long flashes followed by 2 short ones. Then I am getting 1 long one followed by 1 short one. After that it just goes on solid.
I really would like to get my SRS light to turn off. Luckily there is no emissions inspection where I live so the lights on the dash are the only things that could give me trouble.
Just got done poking around my car......There isn't even on there! Either that or I am looking in the wrong place...
Not that I know of...Lets put it this way, the people I bought it from were less than reputable. The swap was done incorrectly and it was running on the wrong computer, there weren't even seat belts in the car when I bought it. All of the problems that I bought with the car are resolved, except for this current one. I do know, however, that there is no problem with the frame at all and that there is no rust underneath my car.
509ernie
05-26-2012 07:22 AM
