OBD0 manifold on B20/vtec FITV hook up?
I have an OBD0 manifold and T body on my B20/vtec. The FITV has 2 connections on it one of which is hooked into the manifold and I have no other connections on the engine, so what do I do with this other port? Can I just plug it up? I know that on other b16 FITV there is only on fitting and the FITV itself is attached to the T-body and not the manifold. I would of searched but search is not working now and I need an answer soon. Thanks in advance.
Re: OBD0 manifold on B20/vtec FITV hook up? (hbracer93)
I would tell you just to bypass the FITV, but you live in CT so you might want it if you have problems with your throttle plate freezing.
The other port goes to the IACV. The second port on the IACV goes back to the motor.
Get rid of the OBD0 tb. It's smaller diameter than later tb's, isn't it?
see the T-body itself has 2 fittings as well. As you can see in the picture I have the IACV running into the one fitting on the T-body, then the other side of the T-body runs to the water jacket I think. Then i ran the FITV to the manifold and just pluggged off the other fitting on the FITV. Is this OK?
Beyond Imagination
32
08-06-2004 03:12 PM
